Sorry, did a search and found nothing, but probably using the wrong search words.
Is there a way to easily run the torch through the g-code generated without the torch firing? Just want to watch the cut path and moves.
TIA
Trial Cut Path
- tnbndr
Trial Cut Path
Re: Trial Cut Path
I assume you have DTHC is so you can click off that function on the program page of Mach, but you may also need to short the ARC OK signal so it thinks the torch is on.
- _Ogre
Re: Trial Cut Path
turn the plasma and thc off
often after tooling change, i'll forget to turn on the plasma and it traces
an ogre smiley
how cool!
an ogre smiley
- exapprentice
Re: Trial Cut Path
I am sure on the Arclight web site there is a video showing the set up and what to do if you want to "Dry Run" or "Trial Cut Path" of a file with out the torch firing,
In fact I am positive
there is a video of this on their site, might be of some help
Best Regards to all
Exapprentice
(Pete)
10'x5' DIY table / PM 45XP + M/C Torch - Trying to add 4 axis Tube cutting
Exapprentice
(Pete)
- WyoGreen
Re: Trial Cut Path
I often turn off the plasma cutter when I want to dry run a g-code file in Mach3. Sometimes you have to hit run after each touch-off, sometimes you have to hit the fire torch button after each touch-off.
Router
Laser
Router
Laser
Re: Trial Cut Path
It use to be real easy before I upgraded to the last Candcnc download. Plasma off, and hit run,then fire button . Now I have to flip the Arc good switch I put in to the system to get it to move. (Also plasma off.) Not a big deal, but it still will run though all it's code that way..The vid of the Arclight does not work the way mine does now..
- tnbndr
Re: Trial Cut Path
Thanks All.
Watched the video and will try soon.
