First art to cut- help please
HEMTEC2020
Post by HEMTEC2020 »
Hi
I have been asked to cut the attached dark vader mask for a customer. I have converted to dxf no problem. But I believe when cut out all the parts will be loose. Did I have to make connection around the mask to hold it together. I use autocad.
Just asking as I don't want to waste materials.
Hemtec2020
Dark vader.pdf
jfelker81
Re: First art to cut- help please
Post by jfelker81 »
Looks good except for the area's iv'e colored red, you will lose these. They must be attached some how to something else. I use AutoCad as well along with Corel Draw 8. :D
Cincinnati CL-940 4000 watt Fiberoptic Laser 5' x 10' Dual Pallet
Why not cut it as separate parts and attach them to a background for a 3-D layered look
seajinx
Post by seajinx »
This should get you started in the right direction. Haven't tried to cut, it may need some tweaking at the narrow areas.
Darth Vader.dxf
Proballz03
Post by Proballz03 »
thanks for sharing
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
Copp3r
Post by Copp3r »
Hey folks,
while this post is a number of years old, I found I had to go looking for a Darth Vader DXF to pass along a gift to a friend. Here's my rendition (very similar to what's posted) with a few changes to smooth out lines, etc.
The pattern has been powder coated: Obsidian Black on the outer face and Silk Satin Black forming the recessed / back area.
Hope it helps out anyone in need...
Copp3r
Darth Vader.dxf
Darth Vader.pcm
Cool, I like it. Thanks Copp3r😎
