Hi
I have been asked to cut the attached dark vader mask for a customer. I have converted to dxf no problem. But I believe when cut out all the parts will be loose. Did I have to make connection around the mask to hold it together. I use autocad.
Just asking as I don't want to waste materials.
Hemtec2020
First art to cut- help please
Re: First art to cut- help please
Looks good except for the area's iv'e colored red, you will lose these. They must be attached some how to something else. I use AutoCad as well along with Corel Draw 8.
Cincinnati CL-940 4000 watt Fiberoptic Laser 5' x 10' Dual Pallet
Why not cut it as separate parts and attach them to a background for a 3-D layered look
This should get you started in the right direction. Haven't tried to cut, it may need some tweaking at the narrow areas.
thanks for sharing
PlasmaRoute "DO NOT BUY there Plasma table from this company NO Support"
Thermal Dynamics A-60
ArtCam
Sheet Cam
Mach3
Refrigerator dry Air
Charlotte,NC
https://www.facebook.com/pages/ACSD-Art ... 90?fref=ts
ArtCam
Sheet Cam
Mach3
Charlotte,NC
- Copp3r
Hey folks,
while this post is a number of years old, I found I had to go looking for a Darth Vader DXF to pass along a gift to a friend. Here's my rendition (very similar to what's posted) with a few changes to smooth out lines, etc.
The pattern has been powder coated: Obsidian Black on the outer face and Silk Satin Black forming the recessed / back area.
Hope it helps out anyone in need...
Copp3r
Copp3r
Cool, I like it. Thanks Copp3r
