4x4 welding table help
richiemirtsching
Post by richiemirtsching »
Looking for a 4x4 welding table DXF or Plasma Cam Pattern.Any help would be greatly appreciated. Thank you.
SONIC
Re: 4x4 welding table help
Post by SONIC »
What exactly do you need?
My welding table is a 4x8 piece of 3/8 with legs.
sphurley
Post by sphurley »
Guy on ebay, took the tab and slot tables design (and photos) and sells the plans
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
hemichargersrt8
Post by hemichargersrt8 »
here is one version I have drawn. I laser cut and carefully welded to reduce excessive heat. Because of the puzzle tabs, the table assembled very flat and stable. I will upload the accessories when I get a chance.
fixture top 29-5X47-5 375 ms 1 pce.dxf
fixture rib short 29-5X47-5 187 ms 5 pcs.dxf
fixture rib long 29-5X47-5 187 ms 4 pcs.dxf
radicalrescue
Post by radicalrescue »
hemichargersrt8 thanks for that file i have wanted a table like that for years
motoguy
Post by motoguy »
hemichargersrt8 - thank you for sharing! I have wanted to design a table like this for a while now. Thanks again!
Largemouthlou
Post by Largemouthlou »
Thank you very much!!
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
hemichargersrt8
Here is the large accessory piece. As with the table, all the parts are cut with 3/16" mild steel. I allowed .003" clearance around all puzzle tables. 5/8" holes for standard table clamps.
fixture square side plate 187 ms 2 pcs.dxf
fixture square top plate 187 ms 2 pcs.dxf
fixture square front plate 187 ms 1 pce.dxf
fixture square middle plate 187 ms 1 pce.dxf
fixture square bottom plate 187 ms 1 pce.dxf
hemichargersrt8
here is a pic of the underside of the table
little blue choo
Post by little blue choo »
Darn you hemichargersrt8 now I have to upgrade my welding table. Love it man love it! By the way I'm a MOPAR man also, most of mine are 1973 and back. Dusters, Darts, Cuda and Roadrunner.
Rick
Rick
Arclight 9600 4x8 table
hemichargersrt8
Rick, I will keep adding accessories for this table. I am a long time mopar fan, but really since 2006, been a SRT buyer. Current ride is a plum crazy 2016 hellcat challenger. Quite the ride!
hemichargersrt8
small angle fixture
fixture angle gusset 187 ms 4 pcs.DXF
fixture angle long 187 ms 2 pcs.DXF
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Wow, thank you for the share! Awesome design.
richiemirtsching
that is what I'm looking for you are awesome
hemichargersrt8
Here is a shelf and light mount for the table. I cut slots in the shelf panel to make bending by hand easier. Bend the front and back flanges first and then fold the end panels up. Tack weld as necessary. The shelf is 11 ga mild steel and the post mounting pads are 3/16" mild steel with 1 x 1 posts
fixture post pad 187 ms 2 pcs.DXF
fixture shelf 11 ga ms.DXF
motoguy
Post by motoguy »
I am definitely cutting one of these! I see your .003 gap comment, for laser. Anyone have a suggestion for plasma cutting?
Lowagon
Post by Lowagon »
excellent share hemichargersrt8, thank you
hemichargersrt8
Motoguy raised a valid concern and since I don't have access to a plasma table, I created a test piece. Cut two of the puzzle test pieces prior to cutting to test your tables offsets. The puzzle tabs should fit into the slots.
fixture tab test 187 ms 2 pcs.DXF
sr guy
Post by sr guy »
awesome job thanks for the share!!
LDR 4x8 w scribe :D
Miller syncrowave 250
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
motoguy
Post by motoguy »
hemichargersrt8 wrote:Motoguy raised a valid concern and since I don't have access to a plasma table, I created a test piece. Cut two of the puzzle test pieces prior to cutting to test your tables offsets. The puzzle tabs should fit into the slots.
My hat is off, sir. You are definitely going above and beyond on this. Thanks!
richiemirtsching
Yes thank you for the help
scottlane
Post by scottlane »
Thanks for the file. Looks great.
badassr1
Post by badassr1 »
Yes sir thanks a ton I just started one of these a week ago.. Save me a lot of time.. Big thanks
hemichargersrt8
To help hold the table top and slats temporarily until you have the assembly tacked together, cut a handful of these brackets out of some scrap steel. As you assemble, bolt in a few locations to make your life easier.
fixture assy bracket 187 ms.DXF
sr guy
Post by sr guy »
https://www.amazon.com/Construction-Rea ... 2F8+reamer
Im thinking this will work to make sure the holes have no taper after cutting. Any ideas thoughts or comments?
LDR 4x8 w scribe :D
Hobart ironman 230
Baliegh tn 250
Bantam 12 ton 48"
JD2 model 32
