How do you mark the center of a hole in a CAD drawing, I want to layout where to drill a hole on a drawing but cannot find a tool to do it.
I am using TurboCad 20 but info about other software may point me in a direction that would help. I have been drawing very small circles like 0.002". There must be a better way for the center to show in a DXF drawing
Drill center mark
Drill center mark
- SeanP
Re: Drill center mark
Do you not just use the hole as drawn and then use drill tool in sheetcam and then choose min/max hole size.
Tophole is 12mm dia, second is 13mm, then 13.5 &14 below.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
What I found was in QCAD they had under Draw, Points, and then single point would give me a dot but did not want to learn another program.
When to TurboCad and was able to use the circle tool set to 0.001 diameter and then located where I want them.
I just draw a plus sign or a X over the center point location and then draw a circle to the drill size to make sure it clearly marks the spot and someone doesn't drill where a random scratch may be...... oh yeah, then I etch those marks in.....
- steel 35
For the machine drill I use .125 circles.
For a center punch template. I Use a Donut adjusted for my eyes,
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Hyp 65 duramax's
EasyScriber
If you use Fusion 360 there is a provision for inserting a center marking + . Just select the circle and then click on the centerline marking icon.
Geo Magic makes you jump trough hoops and set it in preferences.
SpaceClaim is pretty east also.
Thanks for the replies have fun
Tom
Tom
