Arbor image cutting shop
cstroke
Post by cstroke »
Hey All,
Weird one here that I'm having.
http://plasmaspider.com/viewtopic.php?f ... rk#p141179
When I open this file I can see it in autocad but when I open it in cutting shop there is nothing there.
I've seen this happen a few other times but very rarely.
Any advice on this one?
Chris
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Re: Arbor image cutting shop
Post by tnbndr »
When you do "save as" select the oldest possible autocad dxf format available and try that.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
cstroke
Post by cstroke »
Yes save it as a 2000 autocad dxf. save in draftsight, took it to work and ran it through the water jet program and saved the dxf and nothing.
weird one I see every once in a while.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
