Hey All,
Weird one here that I'm having.
http://plasmaspider.com/viewtopic.php?f ... rk#p141179
When I open this file I can see it in autocad but when I open it in cutting shop there is nothing there.
I've seen this happen a few other times but very rarely.
Any advice on this one?
Chris
Arbor image cutting shop
- cstroke
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
- tnbndr
Re: Arbor image cutting shop
When you do "save as" select the oldest possible autocad dxf format available and try that.
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
- cstroke
Yes save it as a 2000 autocad dxf. save in draftsight, took it to work and ran it through the water jet program and saved the dxf and nothing.
weird one I see every once in a while.
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
12’ Wysong brake
3.8’x10’ shear
65 Ton ironworker
SFX 100watt Mopa
Quicncy 7.5hp
