newby needing help
pcilse33
newby needing help
Post by pcilse33 »
I want to buy some dxf art but I currently use Adobe Illustrator and can't get the files to open. Any suggestions on how to make Illustrator work or a name of a software product I can use.
Thanks for any help
Re: newby needing help
Inkscape comes to mind and it's FREE!
Gamelord
4.5 Star Member
4.5 Star Member
Post by Gamelord »
Did you try to import them? I am pretty sure Adobe can do it.
MemFor
Post by MemFor »
You can do it with adobe Illustrator. Sometimes I find that certain older dxf files do not open properly, but easy fix. Convert the dxf to a pdf through online converter of your choice. Once you open the PDF in Illustrator remove the clipping masks then good to go!
