I want to buy some dxf art but I currently use Adobe Illustrator and can't get the files to open. Any suggestions on how to make Illustrator work or a name of a software product I can use.
Thanks for any help
newby needing help
- Larry83301
Re: newby needing help
Inkscape comes to mind and it's FREE!
- Gamelord
- 4.5 Star Member
Did you try to import them? I am pretty sure Adobe can do it.
Torchmate CAD
Torchmate CAD
- MemFor
You can do it with adobe Illustrator. Sometimes I find that certain older dxf files do not open properly, but easy fix. Convert the dxf to a pdf through online converter of your choice. Once you open the PDF in Illustrator remove the clipping masks then good to go!
