4x4 welding table help
bryancab
Re: 4x4 welding table help
Post by bryancab »
have to say I have seen a lot of things but this is the best layed out well thought out I have ever seen
we need to start a go fund me just for your time
ABLE CUTTING & FABRICATION
torchmate 4800
BATON ROUGE, LA
hemichargersrt8
Post by hemichargersrt8 »
Hello all, I have been asked for smaller squares, so here goes.
On a personal note, thank you all for the kind comments. To those that have sent monetary gifts, a really big thank you. To those who took the time to post pictures, I really appreciate the feed back!
Basically, I have put together two styles of squares. These can be clamped or bolted to the welding table. They also can be clamped or bolted together to created various combinations. I did not invent these squares, probably developed by the "Romans", I simply have looked across the internet and compiled the best ideas into two squares. As usual all of the parts have puzzle tabs for assembly.
hemichargersrt8
The first is the tri square, all pieces are cut from .25" mild steel and welded together. I have included a template that will help keep the pieces square to each other when welding. Bolt the template (I have colored the template yellow). Then position and clamp the parts around the template. Be sure to use just enough weld to form a solid assembly, but not so much as to warped the assembly from excessive heat. I would imagine that you can reuse the template as a square as well when the project is completed.
Last edited by hemichargersrt8 on Sun Apr 09, 2017 11:22 am, edited 1 time in total.
hemichargersrt8
The next square is built in the same way, all puzzle tabbed and has a welding assembly template included as well.
steel 35
Post by steel 35 »
Thanks so much :D
PPL HDG 4X8
Hyp 65 duramax's
C&CNC 620-5 Ethernet
Corel X7 Student NO DXF!
EasyScriber
Faulknerm
Post by Faulknerm »
Wow, that's awesome! Thanks again for sharing. I'm still willing to send a paypal gift! I pm'd you about it, but haven't got a response yet.
AIRFLOWKID
Post by AIRFLOWKID »
Thank you so much!
Prioritywelding
Post by Prioritywelding »
Nice work for sure.. Has anyone made this 4x4x1/4 or 4x6x1/4
rdj357
Post by rdj357 »
Thanks so very much for the share, great work and great design!!
Robert Johnson
PlasmaCAM GURU & Instructor
Bigstax
Post by Bigstax »
Great work
great design
thank you
Funbum
Post by Funbum »
Amazing!!! Thank you!!
Prototypetom
Post by Prototypetom »
Simply awesome this is going to be my first build and I will document it I might modify the table structure to house my gas bottle and tig welder but apart from that I can't wait to get this cut
Sampson Jones
Post by Sampson Jones »
Thank You !!!!
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
BlackDragon69
Post by BlackDragon69 »
This is awasome and somuch appreciated.!! Now just to find the time to do the build! I may have to move it up the 'To Do List"...
Wife will understand ?? :)
Pecanman
Post by Pecanman »
Great stuff!! Thank You!!
radicalrescue
Post by radicalrescue »
Faulknerm wrote:Wow, that's awesome! Thanks again for sharing. I'm still willing to send a paypal gift! I pm'd you about it, but haven't got a response yet.
we r still waiting
stuk4x4
Post by stuk4x4 »
Very nice stuff, it will be a while before I make a new table like this but I appreciate all the time and effort put into making and sharing these files. Thanks again
Walt
Poh
Post by Poh »
Man, Thank you for the awesome files!
Poh, Stainless is Forever!!!
Torchmate 5'x10' water table,Torchmate 8 CAD
Hypertherm HSD 130
Plate Marker ,Tube Cutter, and Oxy-Acetylene
Miller Dynasty 350
Miller 350 p
bryancab
Post by bryancab »
in torchmate cad how to you apply a offset to the object to increase or decrease the size for a different thickness material
torchmate 4800
BATON ROUGE, LA
tylerd
Post by tylerd »
Awesome post! Can the table be cut in 1\4" also? Or would that mess up the tab\slot ratio? Either way thanks! I know what my first cuts on my new table will be!
Bulltear 4x8
PN200 Pendant
Linux Command CNC
Hypertherm PM 85
C&CNC Bladerunner Servo
DTHC IV Feather Touch
HyT-Connect DCP-01
Sheetcam Inkscape QCAD
irish1122
Post by irish1122 »
This is awesome stuff. Ive wanted a fixture table for years now. Just havent pulled the trigger on trying to design one myself. Thanks for the work.
Uzaree
Post by Uzaree »
Great work, I would offer a suggestion thought. I would make all your holes 16MM because it fits all the strong hand tools. Also, the 16 MM give enough room for the shoulder etc.
I build my tables with sides. I do use my laser for my tables though and I know Plasma isn’t as accurate.
Amada CO2 3500 laser
Amada NT1303 CNC Press Brake
HAAS ST35Y
HAAS VF4SS
Solidworks CAD design
Tube Bending
Welding and Fabrication
hemichargersrt8
Thanks and yes, the new table plans I posted some time ago use 16mm (.63") holes.
http://plasmaspider.com/viewtopic.php?f=6&t=23989
Uzaree
Post by Uzaree »
ok, I must have missed that. Great work btw That's awesome that you're sharing these.
HAAS ST35Y
HAAS VF4SS
Tube Bending
ETCWeld
Post by ETCWeld »
I can't wait to build one of these! This one project made joining this site a must!
Thanks for all the info and incite
