CAD SOFTWARE..WHAT S BEST ONE ?
Dishtech55
Post by Dishtech55 »
I m newby....and wanting to buy a new Cad software.. I see there is so much Cad software out there..Qcad ,autocad, ect...I want it for my Dxf,Svg files for my Plasma Table files. Have been having trouble with files from this site.and most says they pull up good in there Cad software. so that is why Im going to buy some.thanks.. :D
4x10 Home Built Super Table.
4x4x6` Home Built LP Powder Coat oven
Hypertherm 45 xp plasma cutter
Eastwood 60 amp Plasma Cutter
Eastwood Powder Coating Gun
Miller 252 Mig with Spool Gun
Lincoln 100 Mig
Build Trailers
WyoGreen
Re: CAD SOFTWARE..WHAT S BEST ONE ?
Post by WyoGreen »
It really depends on what sort of things you cut. If you cut geometrical shapes (brackets, etc.) then you'd want a CAD type program. If you cut "artsy" type things, then you'd want something more like Inkscape (free program) or CorelDraw (not free, but the program I use). Both of them will do cad type stuff, but are much easier to use on artsy type stuff. The trouble with .dxf files is there are so many versions of them. CorelDraw will output almost all of the different types of .dxf files. Not sure about Inkscape's outputs.
Router
Laser
Dishtech55
WyoGreen wrote: Tue Jan 22, 2019 7:53 pm It really depends on what sort of things you cut. If you cut geometrical shapes (brackets, etc.) then you'd want a CAD type program. If you cut "artsy" type things, then you'd want something more like Inkscape (free program) or CorelDraw (not free, but the program I use). Both of them will do cad type stuff, but are much easier to use on artsy type stuff. The trouble with .dxf files is there are so many versions of them. CorelDraw will output almost all of the different types of .dxf files. Not sure about Inkscape's outputs.
Thanks Steve..Im going to buy Qcad,,and CorelDraw programs.Im learning my Inkscape right now.its finally getting little easier. Lol
Lincoln 100 Mig
Build Trailers
Post by djreiswig »
I use DraftSight, they have a free version.
I use TurboCad 2018 it is not free (about $150.) but I found it easy to learn with no previous experience of any kind and have been able to draw for both CNC plasma and 3-D projects, still not an expert. :lol:
Old Iron
Post by Old Iron »
I have Qcad and for whatever reason, it doesn't play well with a few of the DXF files offered on this site. Other than that it's pretty easy to use.
robertspark
Post by robertspark »
Draft sight is very similar to Autodesk AutoCAD LT and it's free (for personal use)
Dishtech55
acourtjester wrote: Tue Jan 22, 2019 9:39 pm I use TurboCad 2018 it is not free (about $150.) but I found it easy to learn with no previous experience of any kind and have been able to draw for both CNC plasma and 3-D projects, still not an expert. :lol:
So you think this Program is alot easier to learn on?? That is a plus...been working with Inkscape for about a month now.Some days I have to walk away..Lol Ill look into it..Thanks
Lincoln 100 Mig
Build Trailers
Dishtech55
Thanks Guys for your input..Really like this site.everyone so far is very helpful..hope,my wife and I can get all this down..and help others in the future..thanks again...
Lincoln 100 Mig
Build Trailers
Dishtech55 I sent you a PM about some tutorials for TurboCad
