Cutting Expanded Metal - Which Macine Best
Modernmetal
Post by Modernmetal »
[o]
Team Tracker
Re: Newbie with questions
Post by Team Tracker »
See this older post on cnc zone http://www.cnczone.com/forums/cnc_plasm ... hines.html
This individual has a Hypertherm 1000 doing a great job on perforated metal.
1-800-590-7804
The Hypertherm units have a special pilot arc controller and a selector switch on the front panel specifically designed for cutting expended metal. When cutting over metal, the arc is cutting normally....as soon as a hole is sensed, the pilot arc controller quickly lowers the current to minimize nozzle wear....and rapidly ramps it back up when it gets back over the metal. You will have to put the height control system into manual mode for cutting expanded metal.
Jim Colt
Modernmetal
Thanks Jim.
Very useful info. I appreciate it.
Re: Cutting Expanded Metal
Post by BrianMick »
jimcolt wrote:The Hypertherm units have a special pilot arc controller and a selector switch on the front panel specifically designed for cutting expended metal. When cutting over metal, the arc is cutting normally....as soon as a hole is sensed, the pilot arc controller quickly lowers the current to minimize nozzle wear....and rapidly ramps it back up when it gets back over the metal. You will have to put the height control system into manual mode for cutting expanded metal.
Jim Colt
I have a hypertherm 1650 with this feature and think it works great
boodog710
Post by boodog710 »
I have a Dynatorch with a Hypertherm 1250. Cutting expanded metal is easy: turn off the THC and flip a switch on the front of the Hypertherm. Start the cut over metal portion on the EM.
Post by Dennis »
I cut expanded metal on my Fastcut table works great.. :D
Scratch
Post by Scratch »
I have a TD 151 and it cuts expanded metal fine also. I image most of the big names will cut it fine. TD has a setting for it.
