GM Corporate 14 Bolt drawings.
TRFabworx
Re: GM Corporate 14 Bolt drawings.
Post by TRFabworx »
Do you have the corrected file of the updated version with the bolt hole locations?
Ktenery
Post by Ktenery »
Thanks for the share and the hard work you put into these. This will come in very useful for our mud truck build. I will post up pictures when we get everything cut out and welded together
4linked
Post by 4linked »
Did the original thread starter ever post up that pinion guard as a DXF?? Does anyone else have a file for a pinion guard?? Thanks!
ROKCRLER
Post by ROKCRLER »
4linked wrote: Fri Feb 19, 2021 4:29 pm Did the original thread starter ever post up that pinion guard as a DXF?? Does anyone else have a file for a pinion guard?? Thanks!
I have not cut this yet..
14BoltPinionguard.DXF
4x8 Dynatorch
PM85
~Mo~
ROKCRLER
Post by ROKCRLER »
Original DXF file from the OP also has it in there.
4x8 Dynatorch
PM85
~Mo~
freerider15
Post by freerider15 »
Any chance that anyone has these that can email them to me?
Paypal is having fits trying to let me re-up my membership, and I'm looking for just the ring pattern for the pinion (don't need the full guard, just the ring)...trying to cut this evening/tomorrow.
Here is a drawing that may help you to draw it for yourself. Otherwise I would recommend getting your Paypal account straightened out so you can become a contributing member and have access to the actual files.
freerider15
adbuch wrote: Fri Apr 26, 2024 7:17 pm Here is a drawing that may help you to draw it for yourself. Otherwise I would recommend getting your Paypal account straightened out so you can become a contributing member and have access to the actual files.
It won't even let me see the drawing you posted.
Emailed admins and I'll see what they say.
I've been trying to fix things with PayPal, but that's usually about as fruitful as explaining particle physics to a toddler.
freerider15
adbuch wrote: Fri Apr 26, 2024 8:25 pm
Thank you!!!
