few things i've accomplished lately
oldsoulmetal
Post by oldsoulmetal »
hope you enjoy. all coloring was done with a torch.
welcome saw blade.jpg (98.98 KiB) Viewed 1982 times
sunset scene.jpg (131.47 KiB) Viewed 1982 times
fairy welcome.jpg (138.14 KiB) Viewed 1982 times
fairy wall scounce.jpg (84.71 KiB) Viewed 1982 times
wolf blade 3d relief.jpg (90.19 KiB) Viewed 1982 times
eagle 3d relief.jpg (90.71 KiB) Viewed 1982 times
elkriverfab
Re: few things i've accomplished lately
Post by elkriverfab »
Oldsoulmetal,
Those are very nice.
I like the torch look a lot.
I like powder coating, liquid effects and others as well but on some items that real torch color is hard to top.
I would really like to start experimenting with the torch heat coloring.
They look great.
DXF
Post by DXF »
Excellent. I love the Fairies and the torch effect. How do you do the torch effect without warping things and what kind of gas do you use? I'll have to borrow my welder friend's torch and try it. Looks real cool!
Dave Hanks
AnotherDano
Post by AnotherDano »
I've used a plain old propane/MAPP torch. It's tricky but rewarding.
It's like a box of chocolates.....
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
oldsoulmetal
i use oxy, acetylene with a small brazing tip. about 3 lbs pressure on acetylene and 10-20 on oxygen. this set up seems to allow me some finesse control with the heat. remember to pull of before you get to the color you want. the metal will keep changing color after you remove heat. i also pre- heat a area with the torch so that i spread the heat around. and then go back to the section im coloring. when preheating im not bringing out any color just tring to relax the metal. it seems to help with warpage. but it doesnt eliminate it. hope this helps :)
DXF
Post by DXF »
Thanks for the advice. Sounds kind of tricky but it does look nice. I met a guy in Pana, Illinois who used a propane torch to create the color and then clear coated the pieces.
Dave Hanks
plain ol Bill
Post by plain ol Bill »
I like to keep the torch in one hand and a spritzer bottle of water in the other to help freeze colors. You don't need water often but at times it can come in really handy.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
