I looking for a dxf file for a skidsteer quick-attach plate. Does anyone have one to share?
Doug
Skidsteer quick-attach plate
Re: skidsteer quick-attach plate
This should work for you. This is the one I drew up for work
- Capstone
Thanks for the share.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- otisa2007
its in plasma cam format but heres one i drew up to move plate the triangle brackets go on the bottom and designed for 2" square tubing this is what i use for forks to move plate around with my tractor mabey someone can convert it to dxf
Here is the dxf.
Shane
Shane
here are some bobcat mounts that I cut for a friend sorry i don't have a picture of one finished I always forget to take pictures of finished projects
The side pieces have different angles. Which is top? I don't understand what the triangles are supposed to do. And what are the pieces that look like a house?otisa2007 wrote:its in plasma cam format but heres one i drew up to move plate the triangle brackets go on the bottom and designed for 2" square tubing this is what i use for forks to move plate around with my tractor mabey someone can convert it to dxf
Victor Simonis
Grey Forest MetalCraft
Helotes, TX 78023
210-872-2622
Helotes, TX 78023
210-872-2622
Skid Loader Quick Attach dimensions
I Noticed a few threads dealing with the dimensions, here is the actual spec., with tolerances.
https://wiki.opensourceecology.org/imag ... _j2513.pdf
I have noted that in making various attachments, the spec does not indicate how far off the ground the device is.
So I measure the skid steer with the arms all the way down to get a reference dimension from the plate to the ground.
All skid loaders using this standard are not the same dimension off the ground.
Re: Skid Loader Quick Attach dimensions
Thanks for posting this, PlasmaDon. I've prowled around looking for official specs, found some behind a paywall with a price I refused to pay, etc. This is great!
Shop-built 5x10 table powered by QtPlasmaC
Hypertherm PM 85 machine torch
Lincoln PowerMig 255C
Lincoln Square Wave Tig 255
Ermak SpeedBend Pro
Ermak SpeedBend Pro
Re: Skidsteer quick-attach plate
Here is the PDf in case the link dies:
