Hello. 5x10' plasmacam table grate file ???? please.
Hello , im looking for a dxf or dwg file of the table grates on a plasmacam 5 x 10' table. I have seen 4x8 but not 5x10. Thank you for any help, and keep this site going, its great for learning.
Re: Hello. 5x10' plasmacam table grate file ???? please.
Here ya go mate.
please can you be a dxf file? many thanks from Spain
goyoasturias, are you using PlasmaCam software? It uses pcm.
Hi, I have plasmacam. I have a 5x10 torchmate3 and wanted to put a grid quality
To export a DXF file from plasmacam, hit FILE then EXPORT, then select DXF as the format to save, choose a destination folder, enter a filename, check the boxes for arcs and polylines, and it will save a DXF file to the selected location.
Sorry but the translator does not transmit my words. I have no plasmacam, I have Torchmate CAD.
my apologies
my apologies
- Dennis
many thanks!!!
thanks for sharing
Hi I'm new to this site but a long time welder/fabricator. I am looking for the dxf file to replace the grates for a 5'x10' plasma table.
Much appreciated!!
Much appreciated!!
Ironbite wrote: Thu Sep 26, 2024 4:21 pm Hi I'm new to this site but a long time welder/fabricator. I am looking for the dxf file to replace the grates for a 5'x10' plasma table.
Much appreciated!!
- Joe Jones
Yeah ... There are better designs out there, but those will work.
I suggest you ditch the Samson 510 "waffle" grates and replace them with traditional 1/8"x2" curved flat bar set on edge. The Samson grates work ... but they are a total PITA.
- Joe Jones
Four options. Easily modified for a 4x4 table too. Individually replaceable grate points
Awesome selection to choose from in the topic. I think I will do the replaceable points version Joe posted. Thanks guys
DIY 2x2 table
Everlast 82i
Everlast 82i
- Joe Jones
I drew that one because it made sense. If the small tabs at the ends of the grates slip into a slot to align the material with the edge of the cutting area, why can't the individual points be replaceable as well?AREA wrote: Sun Sep 29, 2024 11:55 am Awesome selection to choose from in the topic. I think I will do the replaceable points version Joe posted. Thanks guys![]()
I have not CUT these grates to test them, so the drawing is simply a modification of the original PlasmaCam files. I don't see why they would not work though.
