Arbor image cutting shop/wecim
cstroke
Post by cstroke »
I have an older version of arbor image cutting shop v 2.0 and wecim 20.
The problem I'm having is every once in a while I cant open a file, program opens but no image.
I can open and see image in autocad and I've even re saved as 2000 autocad but still cant open in either wecim or cutting shop.
The file below is an example of one I cant open.
http://www.plasmaspider.com/download/file.php?id=28927
Any ideas? Like I said it has happened maybe 3 times so far.
Chris
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
Bigrhamr
Re: Arbor image cutting shop/wecim
Post by Bigrhamr »
Gasgas.dxf
(53.64 KiB) Downloaded 82 times
Gasgas.dxf
I have Cutting Shop vs 3.0 and I get that same thing once in a while, mostly with files from here.
I couldn't open that one in CS, nothing there. I have an old version of pcam and imported it there, then exported as a DXF. Then CS did open it, but it was more than a 3 MB file with about a million nodes and many overlapping lines.
Uncleaved and deleted a bunch, then optimized and got this. I may have lost detail in areas like the tires, didn't zoom on the original to check.
illusivedf
Post by illusivedf »
My version does not like to read splines at all, sometimes, lines that are not touching or overlapping will cause it not to read well.
Owner at Illusive Design & Fabrications
http://www.illusivefabrications.com
Air Ride Suspension Parts
Metal Fabrication
Dynatorch 4x8 with Hypertherm 1250
Vinyl Decals & Signs
Powder Coating
