Im thinking I way under bid these but I want to see what you guys would've come in at?
The plates are 23"x29" 16gauge cr steel. The customer is bending the hooks up and painting. We just had to cut and grind them.
I came in at $28.00 each.
They ordered about 10 different plates with all different hooks and spacing/wording. Each design we cut 2-3. so about 30 plates total.
Thanks for your help,
Mike
Price Check. Display Hook Plates
- conz35
"Knowledge is knowing that a tomato is a fruit, but Wisdom is knowing not to put it in a fruit salad."
- Capstone
Re: Price Check. Display Hook Plates
I think you got pretty close actually. I know others will add $10-25 for the overall handling charge for moving around that many sheets, but if you're table is big enough and you can nest full sheet cuts without having to babysit the job, then you probably did ok.
Phil
It's all relative...
CNC Metal Design
Instagram CNC Metal Design
JD Squared 4x8
HT PM45, Miller 251 MIG
CNC Metal Design
JD Squared 4x8
- conz35
Thanks Capstone.
The part i probably messed up then was I didn't add anything for design time; which was over 4 hours to get all of them designed right with hook spacing, hook size.
Thanks again for your input,
mike
mike
- SeanP
If they were all the same then I would be around 25e each as well (roughly same as $) it fairly eats up time when they chop and change designs though.
Powermax XP45
R-Tech 210 Tig, Jasic 250 mig
Table build gallery
Table build gallery
