sheetcam cut speed not recognizing in mach
X-1 Offroad shop
Post by X-1 Offroad shop »
Hello, IM having an issue where when i put in a diffrent cut speed in sheetcam,then post process, and load it up in mach. Mach wont recognize the new cut speed. I have to maually go into g code and chage it in order for the new cut speed to be recognized... is there a glitch or something i need to fix or something in the setup that can correct this? please help.. thanks in advance
WyoGreen
Re: sheetcam cut speed not recognizing in mach
Post by WyoGreen »
The g-code is put out by Sheetcam, so if you are having to edit the g-code in Mach3 to change the cut speed, it sounds like the Sheetcam Post Processor is where the problem is. You could look at the G-code file as it comes out of Sheetcam with a text editor and see what it looks like there just to verify my hypothesis
Without knowing what your Post processor or equipment is, that's the best I can come up with.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
djreiswig
Post by djreiswig »
Do you refresh the operation after you change the tool?
Les Newell
Post by Les Newell »
If you changed the feed in your tool definition you need to use the 'update operations' button to apply it. If you are just tweaking the value for a specific job you are better off changing the feed directly in the operataion.
lcrepairs
Post by lcrepairs »
I have this same issue, when I set a variable or even make a merged tool path with two different feed rates. I have never seen Mach 4 respect those settings. I have brought it up before to my Table Support Tech but I could tell he didn't believe me. It does write it in Gcode but somehow it doesn't make it to the Gcode when loaded into Mach. I have verified this happens weather I'm using Sheetcam or Vectric 2D pro. Therefore I'm guessing it must be a setting in Mach or both Post Processors have an error. Any ideas ??
TruCut CNC XT 4x8
PM-950 Mill
G0776 13x40 Lathe
If you look at your G-code in the first few line you will see G20 (inch) or G21 (metric)
Return to “SheetCam”
