Cutmaster 101 with sl100 table
Big10ton
Post by Big10ton »
I'm new to this and came across this cutmaster 101 with sl100 table which wires do you hook up to the cnc control box to make it fire without having to jumper it. Also running air if that helps. Any honest answers will be greatly appreciated thanks
weldguy
Re: Cutmaster 101 with sl100 table
Post by weldguy »
If you are making it fire with a jumper those 2 wires your jumping would be the 2 wires you would hook up to your cnc controller.
Big10ton
Post by Big10ton »
Ok thanks. I also have a bad relay when I tried to ohm it out it wouldn't so I ordered another one. Thanks for the input on the wiring
weldguy
Post by weldguy »
Your welcome, and good luck :Like
Big10ton
Post by Big10ton »
I replaced the red relay and can jumper the first 2 legs on the plasma start to get it to fire but which wires go to the arc transfer pins. Any and all help would be appreciated Thanks in advance
