John Deere Firering
pipeliner
John Deere Firering
Post by pipeliner »
Heres a special order for neighbor farmer.
Metal Lee
Re: John Deere Firering
Post by Metal Lee »
Nice!
Thanks, Metal Lee
Loyd
Post by Loyd »
My daughter would love that! She and her family are JD freaks! Great job!
Loyd
pipeliner
Post by pipeliner »
Thanks Loyd & Metal Lee, Cut your daughter one out, he it is, the tractor is a John Deere 60.
firering John Deere 60.pcm
(44.01 KiB) Downloaded 269 times
tnttrikes
Post by tnttrikes »
Is someone able to convert to a dxf ?
tnt
DXF
Post by DXF »
Yes. I can if I have a closed path file from pipeliner. I would like a closed path file of it myself. I am creating a Harley burn ring I will trade. Plasma Cam software allows you to export closed paths as DXF files. I am in the process of doing this with over 300 PCM closed path designs. My website is http://www.stonemountainart.com
Dave Hanks
pipeliner
Post by pipeliner »
Kinda lost here on the closed path thing DXF, explain & I'll be glad to help you.
pipeliner
Post by pipeliner »
Here it is in DXF, let me know if its OK.
firering John Deere 60.dxf
(90.62 KiB) Downloaded 355 times
DXF
Post by DXF »
Thanks. When you export or send cut paths (blue color) from Plasma Cam they won't re-connect when down loaded. I sent one to a water jet cutter and she couldn't use it. When you export closed paths as DXF files (almost all CNC macines can use DXF files) all you have to do is click "K" when imported into Plasma Cam software to change them to closed paths (purple color). I'll get back to you on the Harley fire ring - almost done.
Dave Hanks
DXF
Post by DXF »
Sorry, I meant different software (other than Plasm Cam) can't use cut paths downloaded from Plasma Cam as far as I know. Plasma Cam software will use them no problem.
Dave Hanks
DXF
Post by DXF »
Hey. Export the purple one please. You exported the blue one. Thanks
Dave Hanks
pipeliner
Post by pipeliner »
Try this one, it didn't completely turn purple.
john deere old.dxf
(176.81 KiB) Downloaded 350 times
john deere old.dxf
pipeliner
Post by pipeliner »
This one has to work !!!
JD firering.dxf
(674.63 KiB) Downloaded 249 times
JD firering.dxf
Streetwerkz
Post by Streetwerkz »
see if this helps, should be pretty universal now
JD firering.dxf
(126.3 KiB) Downloaded 308 times
JD firering.dxf
Joshua Robinson
www.Streetwerkz.com
DXF
Post by DXF »
I've tried them all and part of the file is in Plasma cam cut paths. The first one works in Plasma Cam as cut paths. When you export Plasma Cam cut paths as DXF files it messes them up. Use browse and send them that way or copy them to a folder and send that way. The PCM closed paths will be all purple (or whatever color that is), open paths are white, and cut paths are blue. You can export closed paths as DXF files that can be used in other software. Maybe you can't find the closed path file you used to create it? This might help. When I create something new I save both a closed path and a cut path together in one file like John Deere fire ring. Then I create another file such as John Deere fire ring 1 to lay out the parts on the table to cut. That makes it easier to import John Deere fire ring into other files you have open. Make sense? Thanks
Dave Hanks
pipeliner
Post by pipeliner »
I'm really getting lost here, I have put many drawings on here with no trouble, some have had to have it in dxf, & I go back to the coral draw version & send that & it works, sorry for the problems I am a pipeline welder by trade & not the sharpest knife in the drawer.
Loyd
Post by Loyd »
PL,
Thank you for the file...my daughter is going to fall out over this... 8-)
Loyd
pipeliner
Post by pipeliner »
Your Welcome, Loyd !!!
