3 layered sign
jeeplogic83
3 layered sign
Post by jeeplogic83 »
Did this for a customer thought I would share. The bronze layer is 1/2" stand off the Bear layer is 1/4" stand off and the COMMUNICATIONS is 3/4" off the silver layer. I had to hang it in it crate before I could take the pic the thing weighs like 50+ pounds. The blemish on the bottom left of the "B" is a reflection off the high gloss clear.
Arc Innovations
Re: 3 layered sign
Post by Arc Innovations »
Thats very professional looking!! How many hours did you put into it?
Arc Innovations
http://ai-metalworks.com
jeeplogic83
Re: 3 layered sign
With design time and powder coat about 6 hours
bwgsmith
Re: 3 layered sign
Post by bwgsmith »
How did you attach the layers?
Bryan
cvmetalman
Re: 3 layered sign
Post by cvmetalman »
that is awesome. the offset distances give it good depth. thanks for sharing.
jeeplogic83
Re: 3 layered sign
I off set the letters with different sized alum spacers. when I build a design like this I add all the holes to the base layer and copy them to the higher layers, the top layer the holes get offset to be smaller, when I cut it out the top layers holes get drilled and tapped to accept a 10-24 sheet metal bolt. I cut off the head of the bolt and screw them all the way in until just the top is showing then weld them in place and grind it flat. Doing it this way no holes or bolt heads are ever seen.
