Lead Ins & Start Points
Charlene
Post by Charlene »
Alright, I imported this file into Sheetcam and everything was reversed. The lead ins are on the outside when they should be on the inside, cutting in the wrong direction, etc. It was created in CorelDraw x5. I have tried simply clicking on the "Reverse Cut Direction" but I can't get the lead-ins to change sides. :?: :?: :shock:
Any help would be greatly appreciated!
Cocker Spaniel house numbers 1.dxf
(124.04 KiB) Downloaded 104 times
muzza
Re: Lead Ins & Start Points
Post by muzza »
Charlene,
In Sheetcam go down to Operations, then on Contour Method change offset from outside to inside or visa versa
Murray
Charlene
Post by Charlene »
Thanks Mirth, I will give that I try.
trucks1948
Post by trucks1948 »
I also use corel x5 and when i import into sheetcam ever so often it changes the lead ins from inside top out.
Return to “SheetCam”
