height contol bouncing
rottenleonard
Post by rottenleonard »
I'm cutting .060 aluminum and I have an issue with the height control bouncing up and down rapidly as it travels intermitantly, It probably is moving an 1/8" up and down, causing a ruffer edge. Any Ideas?
XXTEXX
Re: height contol bouncing
Post by XXTEXX »
Try faster cutting speed.
Craig
Post by Craig »
What version of DE are you using? Do you have Advanced Height Control? Have you tried adjusting the "Arc Voltage Shift"?
Craig Johnson
sled50
Post by sled50 »
We cut a lot of aluminum of various thickness. First make sure you have a good ground from the table to the cut piece. Next check your force when moving setting, make sure it is at least set to 24! I had the same problem awhile back and Brian at tech had me check these. It has been working perfectly since.
